Results 1 to 7 of 7
- Apr 2008
- 188
December 14th, 2009 07:37 PM #1hi guys.. just aquired a grandeur recently.. i noticed that when i switch the A/C on "Auto", setting is at 18 C.. well a/c is very cool inside the car but when you go out and stand near the front door of both sides.. you can feel some hot air comming out underneath the car... parang blower na hot air and lumalabas.. ano kaya ang problema?
December 14th, 2009 08:11 PM #2
- Apr 2008
- 188
December 14th, 2009 10:31 PM #3
yes i know naman that sir, but im just bothered sa hot air that comes for underneath the car everythime i turned on the a/c to auto.
another thing...since digital ang pag set ng temp. napansin ko na kapag 18 lang na setting lumalamig yung buga ng hangin sa loob... when i set it up to 19 mainit na yung buga na parang heater na ang gumagana
December 15th, 2009 09:12 AM #4
danieyoyo,
now, that's almost a clearer description of what you are experiencing. there could be something wrong with your control head. it might be opening the air blend door to heat. try resetting the system by disconnecting the battery for about ten minutes and reconnect. the a/c button usually flashes with the system on if it has detected a problem
jick
- Apr 2008
- 188
December 16th, 2009 09:02 AM #5
December 16th, 2009 01:52 PM #6
danieyoyo,
there is a specific procedure for checking for diagnostic trouble codes for your climate control. at this time, what i recommended to you to disconnect the battery is to try to reset should there have been a malfunction detected by the control unit. as far as "bad effect" disconnecting your battery, is limited to resetting your clock, electronic tuned radio (etr) and maybe some diagnostic trouble codes recorded in your powertrain control module. other than that, it is similar to disconnecting your battery for replacement
jick
December 17th, 2009 12:52 PM #7
it happened before sa van ng friend ko, di gaano nalamig yung aircon, yun pala yung vent ng heater nakabuka kaya halo yung lamig at init. What they did is disconnect the heater hoses, problem solved we don't need it anyway.
