Results 1 to 9 of 9
- Jul 2010
- 41
July 21st, 2011 10:19 AM #12 and 1/2 months pa lang po yung sasakyan ko galing sa casa. kagabi nung pauwi ako biglang may naamoy ako na kakaiba sa kotse ko at nanggaling sa aircon. parang kulob na rubbing alcohol yung amoy. tapos kaninang umaga, wala na nung amoy pero napansin ko, pag binkusan ko yung aircon ko sa kahit anong level, parang parehong amount ng hangin yung lumalabas kahit na lumalakas o humihina yung level ng aircon ko depende kung 1, 2, 3 or 4 yung pinihit ko. yung effort ng parang fan o motor ng aircon malakas pa rin pag nasa 4 at mahina pag nasa 1 pero yung hangin pareho lang.. pero malamig pa rin po, kung nakatodo sa cool yung thermostat at umiinit pa rin pag nakatodo sa hot.
ano kayang problema mga sir? sinubukan kong maghanap sa threads dito kaso parang wala akong nahanap na kapareho sa sitwasyon ko.
- Jul 2010
- 41
July 21st, 2011 03:33 PM #3ahh.. pero sir, bakit minsan nagkakataon halos walang lumalabas na hangin. pero normal naman yung tunog nung aircon sa bawat level ng aircon? pero malamig pa rin at umiinit yung aircon depende kung saan nakaturo sa thermostat.. yung hangin lang po parang hindi nagbabago yung lakas pag nilakasan ko..
July 22nd, 2011 09:23 AM #4
Hi
That happened to me before with my Lancer itlog.
My experience was very similar. First was a foul smell then the air flow was restricted. Eventually the air flow was very minimal but still cold.
Come to find out the evap was severly clogged. Slimy like material, well it was not cleaned for quite some time about 3 years.
Try to have it cleaned and that is usually the solution. Also most cars have cabin air filter which usually needs replacing as mentioned above.
I also noticed that when I use to have the AC cleaned before the evap is usually slimy. I stopped using air freshener and eventually the dust inside the evap changed to loose sticky dust.
In conclusion nga air freshener can shorted the intervals between cleaning.
Good luck
- Nov 2008
- 641
July 22nd, 2011 10:15 AM #6Sir,
Better have your car checked by casa, i'm sure under warranty pa yan since 2-1/2 months old pa lang. Probably mechanical vanes/louver and problema mo since you've mentioned na nagbabago naman tunog ng motor if you change your settings. But of course, its better to consult it with the professionals of casa. BTW Sir, can I ask what model & make of your car is? Thanks!
- Jul 2010
- 41
July 25th, 2011 10:23 AM #7hi all, thanks for replying.
yup, pupunta na ako sa casa in a while para malaman ko na talaga kung ano ito. sana covered ng warranty. suzuki celerio po, 2011.
- Nov 2007
- 164
August 13th, 2011 01:11 PM #9make/model boss?brand new?maron ako na encounter na ganyan kaya lang 6months..butas coil..pwede rin na nagyeyelo o barado ang mga fins ng jelly..o dumi..
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
