Results 31 to 40 of 41
- Jun 2007
- 46
June 29th, 2007 06:45 PM #31Our family wants to get a lite ace, paano ko malalaman kung may over heat problem cya? patukbuhan ko ang makina ng 15% na may A/C ba ????
DIY to death!
- Jan 2003
- 451
June 30th, 2007 11:51 AM #32Ibilad mo sa araw, tapos running at idle only, buksan mo aircon full blast. Check how long before the temp needle goes beyond halfway, if it does at all. This should simulate a bad traffic day on EDSA.
As for the other questions here, our Lite Ace has 3 fans, the viscous clutch fan on the engine and one electric fan each on the 2 condensers. That's how it was when we got it 4 years ago. I think the fan on the condenser next to the radiator was just added on, judging from the mounting brackets used. IOW, obvious na hindi stock.
I've never had overheating problems with this vehicle since the radiator cap fiasco I posted earlier on this thread.
I don't know if this is still relevant, medyo matagal nang na-post yung mga tanong e, but HTH.
- Oct 2006
- 60
July 1st, 2007 11:08 PM #33Most of the time repair shops recommends repairing or replacing radiators, replacing cylender head gaskets, etc. What evryone should do is first try simple solutions first before they get into the hard ones, like cleaning the condensers in front of the radiators with high pressure water and soap and rinsing it for about five minutes solves most overheating problems.
Check also the radiator cap if it has no leak and correct pressure. Also advisable is putting 50/50 coolant and distilled water. This does not stop overheating per se but it maintains cleanliness of the radiators and the engine block which prevents them from rusting, preventing future overheating.
- May 2006
- 5
July 6th, 2007 06:13 PM #34We experienced the same problem. Pag nakatigil ng matagal and the aircon is running, umaakyat ang temp. Nawawala din ang lamig ng aircon.
The problem was caused by the auxilliary fan ( hindi umaandar.) There are 2 fans on the radiator, and only 1 was spinning. If the aircon is ON, dapat parehong umiikot yun.
Just pop the hood, and check if both fans are spinning.
- May 2009
- 2
May 4th, 2009 06:36 PM #35mga boss! newbie here... i just bought a 1994 toyota liteace gxl sabi ng may ari bago bilhin ang problema nga daw is your overheating pag halimbawa traffic tumtaas ang temp lalo na pag nak on yung aircon...so ang gingawa niya daw pinpatay niya lang yung aircon sa likod tapos nag no-normalize na daw ang temp...tapos na consult na daw niya sa mechanic niya about the problem...ang sabi daw dapat paghiwalayin yung condenser sa radiator...kasi magkatapat daw yun...question is... totoo ba to? or may nakatry na ba sa inyo nito? baka kasi sayang lang gastos tapos ganun din pala... meron din nagsabi na magdagdag daw ng aux fan...ano ba dapat sir ang best possible solution??? help naman dyan...salamat!
DIY to death!
- Jan 2003
- 451
- May 2009
- 2
- Jun 2006
- 2
April 14th, 2013 04:34 PM #40
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
