Results 11 to 16 of 16
- Nov 2010
- 236
March 21st, 2013 02:29 PM #11ang ac kasi pag sobra or kulang ang freon kahit konti lang may epekto sa lamig...kung may ga karayom kang leak mawawala talaga lamig pag noon time and pag naka idle kalang(nakaparada)...
sa evaporator may ginagawang leak test bago ikabit (pagkatapos malinisan) ay lalagyan siya ng pressure then ilulubog sa tubig to see kung may magba-bubbles kailangan lang magaling ang tumingin at mapasensya(kung ga karayom lang butas minsan di kaagad limilitaw)...HTH
March 21st, 2013 04:12 PM #12
your car is equipped with a very small engine which can only be equipped with a small compressor and of course small components. the btu per hour should be commensurate to the cooling load and the size of the passenger compartment of the car. if the unit had a bigger unit, it will cool the car even when it is hot. compare your house with a small window type a/c that is not big enough, even if the unit is very efficient, its capacity does not suffice the cooling load
- Oct 2009
- 2,271
March 21st, 2013 05:46 PM #13baka naman naka low level ang thermoswitch ng aircon mo..
sa panahon ngayon sobrang init normal lang na uminit ng kaunti si aircon..
- Jul 2012
- 113
March 25th, 2013 01:44 PM #14sorry mga guru's hindi po ako nakaonline for past days, naging busy po,
Ang dami talagang pwedeng dahilan neto,
by the way po, I have medium black 3M tint po, nag-try po ako ng soap and water way, pero wala ako nakitang bubbles. San po ba may electronic detection leak? How much po ba to? Munoz nga po pala ako nakatira. Sa ngayon po nung dinagdagan nang kunting freon kinakaya na po ng aircon ko yung init.
- Aug 2005
- 553
March 25th, 2013 08:10 PM #15The quickest way to detect a leak is using a halogen leak detector. Its essentially a sniffing device that is calibrated for a particular gas/substance.
March 27th, 2013 02:41 PM #16
Dayuhin mo na si Ceejays sa Las Pinas sir pag may time ka... highly recommended kahit malayo pupuntahan mo sulit gumawa
Traffic!
