Results 11 to 15 of 15
- May 2018
- 611
August 20th, 2018 11:05 AM #11Back in the day when cars weren't that complicated, a lot of folks did that kasi hot naman ang climate sa Pilipinas.
People weren't too concerned about proper warm ups, basta di lang nag-ooverheat, ok na. Of course, this was decades ago, we know better now and cars have changed. Carryover lang yang suggestion nung aircon guy to the present day, pero obsolote na yung alam niya.
Ngayon radiators are super thin (more efficient design perhaps) and made of plastic ata (lighter and cheaper). No more radiator overhauls. Replace the whole thing lang.
August 20th, 2018 01:52 PM #12
What I learned from Ceejays when they repaired the ac of the old car
1. The 134a gas is more effective in laminated type condenser and evaporator
2. This means kung papalitan mo condenser mo ng laminated type, damay dapat mo na evaporator.
3. Make sure that fan in front can blow enough air in between the fins of the condenser and radiator. If medyo alanganin, you can customise to add additional fans or replace fan motor with a faster one. Or else I demo nila palagi na laging binabasa condenser para lang lumamig
- Aug 2012
- 455
August 21st, 2018 02:09 AM #13ah kaya pala ganun yun sinasabi nila during old days. pag summer daw at tirik ang araw basain lang yun condenser para lumamig and the exhaust fan really play a big role, naka ilan aircon shop ako hinde nila masolve yun issue na pag traffic and mainit mahina lamig ng aircon pero pag rekta takbo ok naman until i go to this one ac shop and told me change my exhaust fan, he compare my exhaust fan and the surplus fan, ang lakas nun surplus, after replacing it swabe na lamig kahit traffic pa.
*Archerfish
i also have the same scenario when my radiator top had cracks, palitan daw ng evercool kesa palitan yun top kasi plastic din daw yun at masisira in time. tsaka tanso daw yun hinde sasabog yun radiator pag nag overheat, but mas costly masabugan ng makina kesa radiator. and besides that car is almost 10 years old na and hinde ko alam anong maintenance ginawa ng may ari before baka hinde lang naalagaan at nawasa water lang nilalagay. so i decided to just overhaul/clean the radiator and palitan yun top plastic, it was running fine until i sold it.
- 49,382
August 21st, 2018 10:06 AM #14there is only one reason why there are plastic-tubbed radiators.
"they're cheaper to manufacture."
Could be that the 2.0 model is lesser in numbers kaya hindi nag-stock unlike the 1.8ltr.
Matigas ang Brake Pedal
