Results 21 to 30 of 36
September 8th, 2017 02:46 AM #21
Care to share kung saan location ng shop for this option bro? Humina na rin lamig ng 1st gen mazda 3 ko. Subukan ko muna i-diy palit ng cabin filter next month pag may time then pa diagnose ko kung ganun pa rin.
Sent from my SM-G950F using Tsikot Forums mobile app
- Sep 2007
- 267
September 8th, 2017 10:19 AM #22To some extent, yes. But sometimes a breakdown demands attention and if you choose the wrong shop/technician, then the problem and expense get really worse. I have been lucky with car aircons. Owned several cars without having to service their AC systems up to the day I sold them. On average ~10 years or so. Aside from the usual cleaning/replacement of the cabin filters, the most I've done is change the magnetic clutches - which is, after all, a wear and tear component. I didn't even have to have them cleaned or topped up with Freon. Having said that, I'll just put out the disclaimer that I never use the aircon's temperature and fan speed on their maximum settings. I also never use cabin air fresheners.
- 52,698
September 8th, 2017 10:47 AM #23not always.
you mess up the car if "you don't know what you're doing."
there are still intelligent and systematic car tinkerers out there.
as one proud car tinkerer said, "i'm not messing with the car. i'm trouble-shooting it".
but if you honestly think that you're messing with the car, then you're probably right!
- Mar 2018
- 66
May 5th, 2018 10:43 PM #24MGA sir ask ko lang pina check ko yung ac ng sentra ko, sabi sa talyer compressor daw sira kelangan palitan. Ask ko lang bukod sa papalitan ang compressor eh lilinisin din ba nila mga tubo at condenser, merin pa bang iba?
Sent from my ASUS_X00DDA using Tapatalk
- Feb 2003
- 1,038
May 5th, 2018 10:54 PM #25Standard yan kapag palit ka ng Compressor need to change expansion valve and filter. Dapat din i flush ng solvents ang condenser and Evaporator. New compressor normally have a pre filled compressor oil so no need to add. Change all O rings para sure wlang leaks, then sabay mo na palit ang belts.
Make sure the condenser fan still performing well, most of old fan is umiikot nga but not enough blowing air.Last edited by Jiggs; May 5th, 2018 at 10:59 PM.
May 7th, 2018 08:53 AM #26
- Dec 2017
- 1,018
May 7th, 2018 09:42 AM #27
- 52,698
May 7th, 2018 09:45 AM #28when my sentra's aircon failed as a result of evaporator leak, someone had it replaced with the cheaper laminated design. the resulting coldness was raw ("hilaw").
it became factory-cold again, when i replaced it with the factory-spec and hideously more expensive serpentine design evaporator.
"there was nothing wrong with the compressor."
- Oct 2017
- 3
September 26th, 2018 12:47 PM #29Hello Masters,
nag try ako pa check and estimate (FREE) ng AC service here in Cavite (Gen Trias to be specific).
--Prob: Bigla nawala ang AC ng oto (96 model corolla). Fan nlng naandar at nalabas.
--Assesment: wala na daw freon, need Kargahan.
--quotation: 1.5K cleanins and freon recharging services, other problems na mkikita along the way, iba ang charge.
question: is it good to go na po ba? or need pa mag hanap ng iba?
Thanks..
- May 2013
- 223
September 26th, 2018 01:08 PM #30
I hope they improve the interior a bit. The current is IMHO low-rent for the price.
2025 Nissan Kicks
