Results 1 to 19 of 19
Threaded View
    Jan 2008
    the radiator cap was actually my first thought... sabi mo kasi napupunta tubig sa reservoir. sign of a faulty cap kasi yun.
    try to check na rin for leaks behind the engine.
    nangyari na rin sakin yung hindi ko makita yung leak due to no visible water puddles on the pavement. kaya pala tumutulo sa ibabaw ng makina sa rear part. the water gets evaporated due to the heat.
    check mo rin yung oil mo. baka nahaluan ng tubig. problem with the head gasket
    rule kasi... if you're loosing water, it's going somewhere else. this is normally a leak (palabas o paloob)
    pero kung yung 1 tabo loss of water mo ay napupunta lahat sa reservoir... it must be something esle
Help overheating na
