Results 1 to 10 of 19
November 21st, 2006 03:20 PM #1
good day mga sir! pag tumatakbo kasi ung oto at naka-aircon, biglang namamatay ung makina? ano po kaya ung problem? kaya d muna k aircon ngayon...the car is a 94 corolla with a 4agze engine
November 21st, 2006 10:17 PM #2
have you throttle body and intake valves cleaned. pag madumi yan, nahihirapan yung engine pag tumatakbo at naka-on ang A/C.
check mo na rin yung A/C system mo kung madumi or sobra/kulang sa freon.
November 22nd, 2006 11:32 AM #3
pang-Workshop dapat yata to...
try browsing sa workshop section, baka may similar problem na.
November 22nd, 2006 02:08 PM #4
I used to have that problem. Without the A/C (aircondition) when coming to a stop..my idle stays at around 600rpm BTW i have an automatic tranny. But when I do that with the A/C on..my idle drops dramatically n sometimes it feels like its gonna die..it will hover around 500rpm. N sometimes with the a/c on n im driving..my car will die n i have to turn off the a/c..quickly switch it to neutral...start the engine..the throw it back in D (Drive). I just adjusted my idle a tad bit higher than what it was currently..n that helped. Because when i switch on the aircon, my idle will drop noticeably..so i just had to compensate. I have a 92 Senta a/t.
November 22nd, 2006 02:50 PM #5
palinis ko po ung throttle body and intake valves nia sa weekend. pinataasan k na rin po ung idle nia nun, kaso ganon pa rin, n besides d na rin economical kung patataasan k pa ulit ung idle nia. sabi ng iba, papalit daw ulit ako ng spark plugs para ititiming...may point ba ung idea na un?
- Nov 2005
- 311
November 22nd, 2006 03:44 PM #6hmm.. have you checked if the vacuum switch valve (vsv) is functioning properly, or there could be a leak in the vacuum system.
November 23rd, 2006 10:34 AM #7
Bro, better have it checked by your suking mekaniko to determine what is causing the problem..better do it asap..
- Sep 2005
- 103
November 23rd, 2006 11:03 AM #9Baka naman may problema ang idle-up ng kotse mo kaya pag on ng aircon hindi tumataas ang idling kaya namamatay makina. try mo pa chek ang idle up ng kotse mo.
November 23rd, 2006 06:41 PM #10
tumirik nga po ko sa parteng aurora kahapon, i did open the aircon kasi sobra init (tanghali kasi), pero pag magmemenor na ko, namamatayan na, then hanggang sa d na umandar...buti na lang naitabi ko pa, so jinumpstart na lang ng mekaniko kasi drain na ung battery. i'll list all the suggestions para madala ko na sa talyer sa weekend
