Results 1 to 9 of 9
- Oct 2012
- 6
February 7th, 2013 06:50 PM #1Baka pwede nyo ako matulungan sa problem ng sasakyan ko
TOYOTA VIOS 1.3 2010 Model
Problem : Ilan araw na po mabaho ang singaw ng aircon..
Kahit binusan ko ng pabango ang sasakyan singaw ng aircon ay mabaho parin..
Parang patay na daga yackk!!!
Binuksan ko yung sa may makina pero parang may balahibo ng pusa..
Hindi ko alam kung anong problem... At napapasukan ba ng daga yung aircon pag sa labas ???
Action : Hindi ko pa nai pa check sa mang gagawa ng aircon
- 52,731
February 7th, 2013 08:04 PM #2
February 7th, 2013 08:45 PM #3
February 7th, 2013 09:06 PM #4
Teka teka, kelan mo ba naamoy yung mabahong singaw? Kung sa pag-start lang ng kotse after a day or so without use, at nawawala rin eventually, tirang lamig lang iyan.
February 7th, 2013 10:14 PM #6
sosyal naman ng daga sa inyo sa aircon pa nakatira...
baka naman may nabasa lang dyan sa flooring or nanikit na pawis sa seat cover? o kaya sapatos sa trunk. heheh..
pasilip mo na lang sir sa casa o aircon specialist just to be sure..
February 8th, 2013 07:39 AM #7
- Oct 2009
- 2,271
February 9th, 2013 02:15 PM #8baka naman ung pusa sumuot dun sa makina mo na may kagat kagat na daga.
tapos nabitawan ung daga kaya gumapang sa at naka pasok sa loob at dun na siya nakamatayan kaya mabaho na..
- Aug 2005
- 553
February 15th, 2013 06:57 PM #9You may have left something aromatic such as food inside the car.
The problem with contemporary A/C's is the fact that their major heat transfer components, i.e. evaporator and condenser, are made of aluminum.
Aluminum doesn't have bacteriostatic properties like the copper/brass evaporators of old.
The evaporator is more relevant at this stage though, so normally if it isn't so severe, turn on your AC and then spray lysol under your dash for a few seconds. This will allow the lysol to come into contact with the cooling coil's fins and disinfect it. Once enough bacteria is killed you should smell less of offensive odors.
If this doesn't work, there's a good chance something died in there and would need to be cleaned more thoroughly.
Freshen the rest of your car's interior especially fabric surfaces.
