Results 11 to 13 of 13
- Jul 2006
- 48
August 3rd, 2009 04:48 PM #11crazy car. cleaned the throttle body of my car last sunday. There was too much gunk, tar like black substance i removed using carb cleaner. Was not able to clean the IACV though. Now the car's rpm does not go down below 800 rpm when Ac is on, but rpm now goes up to 1200 then down then up when AC is off! whew! When car is turned on, idle goes up to 1500 for a 3 seconds then lowers to 1000. Baseline idle seems changed to higher setting. What could be the problem? Did i miss something?
August 3rd, 2009 04:55 PM #12
Looks like your Idle Air Controller Valve is going south bro. Try mo palinis baka sakaling madala bro.
- Oct 2008
- 469
August 4th, 2009 09:13 PM #13Sir same problem po, pasumpong sumpong lang naman po sakin! Pag nag on na compressor, sobrang taas RPM, pero pag namatay na compressor slowly going down na, umaabot sakin til 2000 RPM. Napansin ko lang din po ito pag nag stop ako. Brandnew kabit naman po evaporator and condeser ko last january. Ano po kaya possible problem? thans
Ayos sumabay pa sa Greenbelt 1.
Makati CBD parking
