Results 21 to 30 of 31
- Jun 2008
- 1,741
March 27th, 2010 02:26 PM #21Just my opinion:
Mas ok na parallel ang condenser kung ang physical location ng dalawa any magkalapit. Fitted with isolation valves pwede gamitin ang una kung magkaroon ng leak ang pangalawa or vice versa. Most if not all centralized A/C system na nakita (and work with) ay parallel ang configuration.
- Jun 2008
- 18
March 28th, 2010 06:31 PM #22[SIZE=4]good day mga bro. what is the advantage na mgkalapit ang dalwang condenser, usually kasi sa mga nakikita ko lalo na sa mga van is using isa sa harap ng makina and the other one sa ilalim, lalo na sa mga fx nakikita ko yung isa sa ilalim ng passenger or driver side or medio malayo yung dalawang condenser sa isat isa.[/SIZE]
March 29th, 2010 08:46 AM #23
location, location and location. with todays cars with low hoodline and passenger vans with the windshield almost directly above the radiator grille, the space to place the condenser is very limited, the reason why there are two condensers to still have ample condenser square footage.
April 9th, 2010 08:15 PM #24
sorry sa late response, te-nrace ko mabuti ulit at mukha nga mali pa trace ko. ganun pala sa corrected diagram mo ang setup ko. thanks!
ay opo, parang shut off solenoid nga yung tinangal.
I was looking for the superheated area, but it looks like malamig lahat ng area after sa evaporator tubes, kahit malayo na or papunta balik sa compressor. no heated area. While after the dryer line, mainit parin tubes dun. should I move it there?
- Apr 2009
- 551
April 19th, 2010 10:14 AM #25hello.. singit lang ako. may nagsabi sa akin for dual aircons. sa pag gamit
daw both should be opened? i mean front and back kahit walang passenger
bukas pareho para daw hindi masira. tama ba? base kasi sa nakita kong
connection ng dual aircon sa thread na ito. parang kailangang sabay pagbukas?
Thanks
April 19th, 2010 01:41 PM #26
April 19th, 2010 02:03 PM #27
pwede nakasara likod basta me shut off valve sya (solenoid), para kung harap lang ang paandarin dun lang iikot ang freon, pag in-on mo likod gagana yung valve at tutuloy na sa likod ang freon sabay ang andar ng rear aux condenser. Yung sinasabing masisira daw pag isa lang paandarin, walang valve yun.
- Apr 2009
- 551
May 3rd, 2010 02:33 PM #29
yung single drier sa dual condenser/evaporator, dapat po ba special ang drier nito? or just the common ones used on single setup too...?
May 3rd, 2010 02:43 PM #30
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
