Results 61 to 70 of 74
June 27th, 2013 03:28 PM #61
+1 to ^
May coolant na pre-mixed and ready to use no need to halo (Prestone ata meron sa Ace, some casas also sell them). May coolant din na concentrate that you have to mix with DISTILLED water before using (Prestone again, some gas stations sell their own brands). Know which one you're using.
- Aug 2005
- 553
June 27th, 2013 03:37 PM #62
- Aug 2005
- 553
June 27th, 2013 03:59 PM #65
Actually sinusunod ko lang ung recommendation/instruction na nakasulat sa coolant na binibili ko directly from Honda. As far as I can remember, nakalagay dun na "do not add/mix water". Since the product is from the car manufacturer, I assumed na they know what is best for my ride. FYI, never pa ako naka experience ng overheat sa car ko. With regards to the corrosion, normal na lang cguro na mangyari nga un since 10 years old na ung car. Pero hanggat wala pa naman nagiging problema radiator ko, i will still continue using 100% coolant. IMHO lang naman.
BTW, may mga nakita na rin ako coolant sa ACE Hardware na nirerequire sya as 50% coolant and 50% water. I'm not sure if Preston ba un. Better read carefully the labels para sure.
- Aug 2005
- 553
June 27th, 2013 04:02 PM #66The OEM coolant from the dealership is a pre-mixed coolant. Adding water would simply dilute it.
Actually Honda's standard long life coolants are remarkably good. 10 years or 100,000 km normally in between changes.
But they have 2 types, if I remember correctly, one is the long life. The other I find more casual.
- Aug 2005
- 553
June 28th, 2013 12:29 PM #68Boiling point of pure glycol is 197C.
30% or 40% mixture with water is 107C. Hence why 30% is fine.
Your typical engine maintains anything from 82-90C. Going pure coolant does not do you any good.
Because if you think that a higher boiling point would mean better heat transfer, you are mistaken. Pure Glycol is less than 50% as conductive as water and is far more viscous thereby also limited by its high surface tension to spread out evenly and transfer heat more effectively.Last edited by EVO-V; June 28th, 2013 at 12:32 PM.
June 28th, 2013 01:04 PM #69
Anti corrosion & anti rust & lubricant properties lang naman habol ko sa coolant..
- Aug 2010
- 86
June 29th, 2013 03:04 PM #70
They managed to get that "green plate" for the Ertiga, and I heard/seen news that they're pushing...
Suzuki Fronx
