The car A/C is always damp/moist on the dashboard area. It gets wet after a couple of minutes opening it so we have to keep on wiping the area to remove the water.
Is this normal? The car is brand new.
Naku, sira pa ata yun unit na nakuha ko... di pala normal to, akala ko naman mashado lang malamig kaya moist yun area... Actually di ako satisfied sa unit na nakuha ko.. Yun cigarette lighter hindi na gumagana... than yun tunog nung left passenger door pag binubuksan iba compared sa ibang pinto.
By the way girl pala ako.![]()
^ipatingin niyo iyan sa casa habang maaga. kasi habang tumatagal ang mga ganyan mas lalong dumadami ang problema at masmahihirapan ka ipa-ayos sa casa at ma-isama sa warranty
btw, how long or how recent has the car been w/ you?
check your aircon vent selector dapat naka select ka dun sa icon na may taong nakaupo tapos yung arrow eh naka turo sa mukha nya.. pag naka tapat yan dun sa parang windshield eh mag moist talaga yan kasi yung hangin eh dun pupunta sa windshield /dashboard area...
worst case eh may problem talaga yan a/c mo..
also sa doors dapat maganda ang lapat nyan
and lastly demand for a replacement...brandnew po yan so expect everything is in good condition...sayang bayad mo sa car... nag picanto ka na lang sana or hyundai getz or suzuki alto or toyota vios, kung may minor imperfections eh ok lang siguro since you will not have high expectations... pero for a brandnew honda city mahirap ata yan my expectations are high for that brand
It looks like the air that is being blown out of your evaporator is still humid(wet)....Did you notice if a semblance of smoke is coming out of the vent? My take is the expansion valve or the dehumidifier or both is/are defective....
6110:pepsi:
Could also be that your thermostat is set too a low (cold) and your fan to a low setting. This combination would surely produce moisture around the vent area. Nornally this wold happen in the rainy or cold environment.
Hi... thank you...sige check ko yun position nung vents and i-adjust ko yun vent selector...
And sa tingin mo mag-issue kaya sila ng replacement unit? grabe sobrang na-disappoint ako.. ang dami nang palpak sa car.. mga minor accessorie pero considering na brand new sya.. nakakahinayang din...
