Results 1 to 10 of 10
October 25th, 2018 09:57 AM #1
Hi! Good Day Guys, I bought a used 2012 Suzuki Swift 1.4L Manual Transmission tapos nag plan po ako na palitan ang engine coolant nya.Okay lang po maya na ung Pink na Pro 99 Brand ang gamitin ko? Ang naka lagay po sakanya ngayon ay Green? Pro 99 is the cheapest available coolant po kase PHP 340 for 2 Liters na unlike ni Prestone PHP 500 1 Liter lang.TIA
Sent from my ASUS_Z01MD using Tapatalk
October 25th, 2018 10:15 AM #2
October 25th, 2018 10:29 AM #3
October 25th, 2018 10:47 AM #4
October 25th, 2018 02:50 PM #5
Malaki ba ang price difference ng oem coolant sa aftermarket? Baka konti lang so better off mag oem na wala pa sakit ng ulo
do what you gotta do so you can do what you wanna doLast edited by baludoy; October 25th, 2018 at 03:53 PM.
October 25th, 2018 03:26 PM #6
Stick with OEM or at least something close to it. Yung L300 namin green ang stock nilagyan ng Abro na red nag overheat kasi may namuong coagulants. Nagmistulang gelatin yung ibang parte kaya hindi mag flow nang maayos.
Kung desidido kang magpalit flush talaga dapat. Walang palitan ng coolant hangga't hindi klaro yung lumalabas na tubig.
Ok yung Abro na red o kaya yung mga premixed na pula kasi wala silang antifreeze kaya mas mataas ang boiling point. Pero hindi recommended na direct refill, i-fllush talaga dapat. Nasa 200php pababa kadalasan yung mga premixed/prediluted coolants. Yung ibang mura kapag binasa mo ang label nakalagay 70/30 mixture - 70% water, 30% coolant kaya olats.
- Aug 2017
- 319
October 26th, 2018 12:41 PM #7I operate 16Grab cars since 2014. I've used Pro99 since 2016, both green and pink, both works. I personally prefer the green variety, easier to check vs discoloration that tells you to change the fluid.
I change all fluids once a year. Yes, full flush before fill
Never did I have overheating, unless the aux fan breaks down
No coagulation, no rusting, no noticeable difference
Even compared to just plain absolute distilled water
- Mar 2010
- 301
- Aug 2017
- 319
- Mar 2019
- 41
July 20th, 2019 03:24 AM #10My personal belief is hindi dapat tinitipid ang mga ganyan maintenance. Totoo sasabihin ng iba pare-pareho lang engine coolant or yung gagawa ka na lang ng sarili mong combination ng water and coolant mixture. Mga modern engines like yours ay dapat ginagamitan ng original fluids to avoid corrosion inside the engine and better cooling efficiency. Mas alam yan ng car manufacturer like Suzuki kung bakit yun ang engine coolant na ginamit nila. It is basically a mixture of many different chemicals suited for that type of engine. Yung matitipid mo ngayon ay baka mas magastos pa in the future pag nagkaroon ng sira sa engine mo. One time gastos lang naman yan. Hindi ka naman gagastos ng todo todo every week or every month. Yung original Long Life Engine Coolant ng Toyota ay nagamit ko lang 1 time in 5 years. Imagine, dahil ginagamit ko original from Toyota walang mga leaks and corrosion ang engine ko. Well maintained and super linis inside and out from top to bottom. Just my two cents.
