Results 11 to 20 of 20
November 10th, 2010 12:06 AM #11
From someone who also has an XE with a busted compressor :p
The mirrors and windows blur because the air outside is cooler than the air INSIDE the car where it is heated up by your body heat.... as such moisture condenses on the inside surface of the glass where you can wipe it off while inside the car. Napakadelikado magdrive sa ulan ng walang aircon kasi you cannot see outside your car due to the condensation forming on the glass, which would result in accidents that could cost more than an aircon repair.
A brand new compressor should not cost more than 4K for a Sanden SD series (SD 507, 508) that fits on a 2E engine... 17K daw? Pag nagkasya yun sa puwet niya sige bilhin ko yun.
- Sep 2009
- 35
November 13th, 2010 11:49 AM #12Makikisabay na rin ako sir sa thread na ito. 93 Corolla with 2E engine kasi gamit ko at halos pareho lang ang problema natin. Matagal ng may naglleak sa a/c compressor ko pero di ko pinapansin noon. pero ngaun biglang may tumutunog na sa compressor ko kpag cold start. epekto rin ba yun ng oil leak?
Isa ko pang problema ay kahit nka blower lang ako ay gumagana pa rin ang compressor ko kahit naka OFF ang thermostat.
Ano kaya ang cheap andstill good kind of compressor? Butas na bulsa ko kasi.
Thanks.
- Nov 2009
- 456
November 13th, 2010 02:53 PM #13Yes, ang compressor kasi kelangan din ng lubrication para hindi masira ang moving parts nya. Every time na magpapalinis tayo ng aircon system (usually every year or two) automatic na nilalagyan uli ng panibagong oil sa compressor.
May diperensya sa electrical or sa switch ng thermostat sa dashboard.
There is no such thing as a cheap but good kind of compressor. You get what you pay for.
Kung problema ang budget, pwede mo try na ipa-repair muna yung compressor. Kung hindi pa sira yung coil nya sa loob, malamang pwede pa gawan ng paraan (palit ng bearings for example).
Kung hindi na maremedyuhan, pwede ka humanap ng surplus pero di ka nakakasiguro kung magtatagal sayo yan, used na kasi eh.
- Sep 2009
- 35
November 13th, 2010 09:33 PM #14Thanks for the reply and info boss Civic.. Try ko mag canvass sa mga shops at tanong ko kung magkano aabutin ang repair.
November 17th, 2010 06:52 PM #15
magandang araw po! pasakay na rin po ako sa thread ninyo
napansin ko na lang nung isang araw hindi na malamig ang binubuga ng aircon ng sasakyan ko (2003 mitsubishi L200 endeavor na pickup). hindi ko alam kung gradual ang pagbaba ng temperatura over the course of a few weeks or bigla na lang, basta napansin ko na lang na "pucha ang init na a" hehe
pinatingin ko sa unang nadaanan ko na aircon repair center. pinahiran ng soap water yung mga linya na dinaaranan ng freon/yung mga linyang ginagamit ng aircon. tinuro nila yung sa bandang likod-ilalim ng radiator (sa may katabi ng alternator). sabi nung tech na yung nandun na langis ay indikasyon na may sira yung compressor.
at least yun yung pagkaintindi ko hehe.
tanong ko po:
-may alam po ba kayong malupit (read: honest, affordable, mahusay) na gumagawa ng aircon ng sasakyan?
-kung totoo nga na compressor yung problema, magkano kaya aabutin ko?
ayun lang po. salamat po sa inyong oras.
November 29th, 2010 08:52 AM #16
i have a personal machanic in kalookan named onthoy.
napaka galing po nya kayang kaya nya mga newer
vehicles like fortunner, jazz, crv...
ok po sya sir sasabihin nya sa iyo ang totoong sira
ng aircon hindi yung silip lang eh kesyo kailangan na
agad palitan.. iniisa isa muna nya and if ever
binabaklas muna even the compressor. if hindi naman
sira compressor fully he will just overhaul it.
dyan po sya sa 6th ave cor cordero st. w/ contact
number 09309495105 (call him rather than text)
December 4th, 2010 09:20 AM #17
- Sep 2010
- 131
January 29th, 2011 06:29 PM #18tanong ko na rin, yung oil seal (i guess?) in the compressor pag pinalitan na tapos tumagas uli, ibig sabihin kailangan na talaga palitan compressor or possible na baka hindi maayos pagkakakabit nun
- Jun 2008
- 1,741
January 31st, 2011 10:01 AM #19Possible hindi maayos ang pagkakabit. Kung ang shaft ay hindi pa nag "canal" ang tapat ng seal. kung nagka canal ang shaft, ang isang paraan ay ikabit ang oil seal na hindi tatapat ang sealing lip sa canal. Ang ibang technician ay binababad muna sa langis ang oil seal bago install. Kung hindi na maremedyuhan ang problema ng shaft ang best thing to do is compressor replacement. Ito ang opinion ko.
- Sep 2010
- 131
February 2nd, 2011 08:49 PM #20
pag ngilay ngilayin. to ruminate over or to meditate on. and no boisterous noise or music,...
Traffic!
