Results 1 to 10 of 10
- Jul 2008
- 6
July 19th, 2008 06:28 AM #1bago po ako dito, I have a really old nissan sentra. The problem is, may leak ng tubig from the aircon na tumutulo sa carpet. lagi basa carpet ko, kakapalinis ko pa lang nga aircon. what could be the problem
July 19th, 2008 07:49 AM #2
usually if A/C is leaking water inside the vehicle its just the drain hose getting clogged. But you said you just had the A/C cleaned so you need to check the evaporator housing if there is a crack, or double check the drain hose cause it may have not been installed properly.
- Apr 2008
- 1,557
July 19th, 2008 08:20 AM #3That also happens to me a lot of times with my old car. Sometimes when I remove the carpet it's wet and after about 2 days it's fine again without doing anything with it. I tried to have it checked before and the mechanic just cleaned something. But try to have it checked in a reputable aircon repair shop to be sure.
July 19th, 2008 09:25 AM #4
pasundot mo yung pinapasukan ng drin ng evaporator, dun may bara most likely. ganun din maxima ko,e...
July 19th, 2008 10:08 AM #5
it happended to us once after nmin mg palinis, bumaha sa loob ng auto. wen i checked it, di inayos ng gumawa yung pg balik nya ng mga parts. yung drain hose nya di nakalabas yung tip kya sa loob tumulo....
July 19th, 2008 10:08 AM #6
July 19th, 2008 10:55 AM #7
drain hose lang yan, pasundot mo muna or baka hinde maganda pag ka lagay sa drain hose...
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Jul 2008
- 6
July 22nd, 2008 02:06 AM #10
How bad is the leak?
Drip (condensation) on the A/C dont cause that much problem, its just a very small portion of the carpet was damp and usually it gets dry(sometimes) on the afternoon.
One thing to put more attention is look to see if your HEATER CORE or HOSE is leaking located under the dashboard behind the A/C and Heater control. Follow where the leaks start.
