Results 71 to 80 of 273
- May 2014
- 72
June 1st, 2014 12:32 AM #71[QUOTE=Memphis.Rhaines;2357706]Actually dumaan sya ng thermostat kc nacocontrol ko ung lamig eh. Problema lang tlga nia naka bypass sya sa aux fan relay power supply.
Kng d sya dumaan ng thermostat kht nakalow ung temp, malamig prn. Pero dama ko po ung pag bawaa ng lamig. aah ok basta ngootomatik at umaandar ng maganda ang fan at compresor ok na yan at malamig pero kung ako ttanungin papahanap ko wiring nyan loss lang yan eh
June 3rd, 2014 11:08 PM #72
My Aircon problem with my 2011 Montero started over a month ago. From cold start, the aircon would work normally then suddenly mawawala yung lamig. This continued off and on until I brought it to be serviced
When I had it checked, we immediately noticed that mahina na mabagal yung aux fan so the tech was convinced that this was the source of the problem. Sadly, the next day the problem occurred again on my way home from Makati. During the time na nawawala yung lamig parang normal naman yung cycle ng compressor but wala nga lang lamig. Then Aircon goes to normal after you turn off the engine for a period of time.
Any ideas or suggestions on what the problem could be?
June 5th, 2014 11:36 AM #73
Just now,my almost 2 years old advie is having a problem with the ac unit,malamig naman sya kaya lang minsan ayaw mag otomatik shut off compressor ,May time naman na gumagana ,di ba pag disengage compressor low idle sya,pag engage idle up?,ano kaya problem
- May 2014
- 72
June 5th, 2014 02:19 PM #74
- May 2014
- 72
June 6th, 2014 01:29 AM #77
October 29th, 2015 10:03 PM #78
Mga sir bakit po kaya same ang lakas ng blower sa rear ac kahit anung # ayaw humina ayaw dn lumakas
October 31st, 2015 01:31 PM #80
pag na ubosan ba ng freon overnight hindi aandar compressor?
day before ok naman lami, naririnig yun click sound ng compressor-on, next morning walang click, walang lamig blower lang
