Results 21 to 30 of 273
August 9th, 2010 05:40 PM #21
Sir, gud day po kung malapit po kayo sa makati area,try nyo po patingnan
sa Empire Cool nsa kamagong st. po location para m check up po...
look for Ronald
- Jul 2010
- 166
August 12th, 2010 08:50 AM #22mga sir ako rin po may problem sa compressor ko, pag on ko ng ac maingay (maugong) na compressor ko, tapos halos di makaarangkada koste ko pag naka on ac. corolla 93 po auto ko. last 2months nabuksan na compressor ko dahil nagpalit ng o-ring, nakita nung gumagawa na manipis na daw yung clutch, (clutch nga b tawag dun?) pero kinabit pa rin namin. tapos yun nagumpisa ng umingay compressor ko, sabi ng gumawa palitan na daw compressor. talaga po bang dapat ng palit?
- Nov 2007
- 164
August 13th, 2010 03:46 PM #23
- Aug 2010
- 14
August 28th, 2010 09:43 AM #24sir tanong ku din po problema ng car ko, pag start ko meron maingay ng na parang normal sound na naririnig kapag sira yu pambelt, sabi po ng kaibigan ko pambelt daw po ng aircon kasi kapag pinatay ko yu ac e nawawala yu sound pag naman na i on ulit babalik po yu ingay pero sandali lang naman about 2 minutes lang tapos wala na,
ano po kaya sira ng aircon ko po...pakitulong naman po...
August 28th, 2010 02:46 PM #25
usually aircon belt lang yan. maluwag o malutong na. check mo yun inner side ng belt pag puro crack na papalitan mo
- Nov 2007
- 164
August 29th, 2010 02:35 AM #26
- 10
September 6th, 2010 11:17 AM #27Need your advise guys, had my aircon cleaned by a nearby car aircon technician. They replaced the bearing kasi maingay siya, palit drier, expansion valve, linis evaporator, karga freon. Nawala naman yung ingay and aircon was working fine. Pag uwi ko sa bahay nawala yung lamig. Balik ko sa shop and the compressor is not engaging. Checked everything (freon, etc.) pero wala namang makitang sira including fuses. Nirekta yung compressor and umandar and lumamig siya. Since gabi na and agreed with technician to go back the next day, pag uwi ko before reaching our house gumana na naman yung compressor. Lamig ulit. The next morning ok siya. Unfortunately di na ulit gumana yung compressor when I used the car in the afternoon. this morning di na naman gumaganana yung compressor. Di ko na binalik dun sa aircon shop kasi di na alam nung technician ang gagawin.
What could be the culprit behind? Dinala ko siya kahapon ng umaga sa Cee Jay, unfortunately di naman nagluko. Almost an hour they observe the car, but di naman nagluko. Ill bring it back sa Cee Jay sa Friday and have it checked there. They advise me to leave it there for the whole day para obserbahan in case the same happened again.
Car is Nissan Exalta 2004 pala.
September 6th, 2010 02:18 PM #28
- Nov 2009
- 456
September 6th, 2010 03:03 PM #29
September 6th, 2010 09:22 PM #30
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
