Results 1 to 9 of 9
- Jul 2013
- 2,450
November 27th, 2018 10:08 AM #1Short story:
Yung Toyota Long Life (Red, concentrate) and nabili ko pero Super Long Life (Pink, 50/50 premix) ang nasa manual.
Hindi ko kasi alam na magkaiba pa pala yung dalawa.
Did some google research and mejo conflicting ang opinions.
Toyota red long life & pink super long life same? - Bob Is The Oil Guy
Long Life vs Super Long Life coolant | Tacoma World
I am not a chemist but someone can shed some light.
Red - has sodium benzoate
Pink - plus sebacic acid
Toyota both are compatible/mixable.
So the question is is it safe to use Long Life (Red) after flushing the Pink coolant? Thanks!
November 27th, 2018 12:08 PM #2
if you flush the old coolant, yes
for old cars you do need to change out the coolant anyways. this saves the radiator
for newer cars the coolant does last longer...
- Jul 2013
- 2,450
November 27th, 2018 02:13 PM #3Thanks! I plan to flush with distilled water after draining the old pink coolant. Then put the red coolant 50/50 mix.
Mejo hesistant ako nung una. Baka kasi may internal components na hindi compatible.
Pero mukang ang difference lang ay flushing interval between Red and Pink.
November 27th, 2018 02:58 PM #4
if the vehicle is over 5yrs.. and youre draining the coolant.. one clamp and 2 10mm bolts.. pwede na palitan ang thermostat.. around 500pesos.
- Feb 2014
- 2,536
November 27th, 2018 03:07 PM #5just return the red and get the proper pink coolant
the red has shorter life so you'll be spending more
the way i understand it the red is a conventional coolant, while the pink is a half-a$$ed version of the OAT organic acid coolant like Honda type-2. half-a$$ed coz it preserves compatibility w/ the red coolant but doesn't achieve the 10-yr interval of the honda type-2
- Jul 2013
- 2,450
November 27th, 2018 03:18 PM #6Our Innova is 6 years old. Do you think I need to replace its thermostat? Binasa ko manual pero wala ako na-encounter about thermostat. Anyway, I'll try to locate it and see if I can DIY it in our garage.
Yes Red has shorter life span but is cheaper than Pink. I'll just use the Red since we barely reach 10,000km a year. Baka after 6 years uli bago mag flushing.
- Feb 2014
- 2,536
November 27th, 2018 03:23 PM #7red is conventional coolant so it depletes over time. hindi aabot ng 6yrs yan
think of it as an electrolyte. and the different metals in the loop are your anode and cathode there is constant chemical reactions going on
November 27th, 2018 03:55 PM #8
- Jul 2013
- 2,450
November 28th, 2018 10:00 AM #9
Spare tire lock. I had it installed in my then new Innova at the dealer way back 2015. It was...
