Results 21 to 27 of 27
April 20th, 2009 07:24 PM #21
since climate controlled ang aircon ko, sa umpisa automatic mode muna. then pag naramdaman ko na ok na ang lamig ng sasakyan, sineset ko na sa low ang fan at yung temperature nasa 28 degrees na. ayoko rin masyado mastress out ang compressor habang nasa biyahe.
pero if the climate outside is cold, kahit walang aircon, ok na ko
April 20th, 2009 07:26 PM #22
to all. thanks sa lahat ng posts niyo. helped me realize a thing or two. A/C is there for comfort, so if i want a comfortable ride, kelangan ko i-compromise fuel ko. so far, nag aadjust ako ng A/C setting depende sa situation, ex: morning, noon, galing sa bilad, sa parking, evening, etc. havent tried full thermostat nor full fan speed. after your posts, am between 1/4 ~ 1/2 ng thermostat, and between 1~2 na fan speed. sa experience ko big help din na OK tint mo, right now 3M light black ako sa front then 3M medium black sa sides/rear.
* sir aga. go for the tint, either 3M or Solargard, i think any of the two works best sa present needs mo.
April 20th, 2009 07:53 PM #23
ur welcome tots & thanks wohoo
co nixz kapit bahay lang kita tuktukan ako hahahaha lapit sa munisipyosan makikita pics up mo?
April 22nd, 2009 07:57 AM #24
May 2nd, 2009 08:57 PM #25
Hello everyone! I'd just like to share my opinion on this. I do agree with using window tint. It acts like an insulator keeping the heat out and the cool air in.
Now if you're looking to save on fuel while keeping the a/c on, you can try cycling the a/c at key points:
- Turn a/c off during hillclimbs and when you're accelerating
- 1/2 temperature setting on flat and straight highways
- Maximum temperature setting going downhill
If you want to learn and share more tips and tricks on Driving to Maximize Fuel Economy, visit www.hypermileph.com and logon to the forum. Thanks!
- Jan 2008
- 4,726
May 2nd, 2009 09:10 PM #26agree..
for cars with "climate control" that only mix hot and cold air to adjust cabin temp, its better to set your thermostat to the coldest.. just manually turn off your A/C when you feel cold and turn on as necessary.. this is the best way rather than setting it to 3/4 or whatever setting near the hot zone..
btw, modern engines are more efficient and the A/C load doesn't much affect fuel consumption.. there is already a study conducted regarding A/C turn on and off and the fuel consumption is just the same.. also make sure your A/C is functioning properly to avoid the engine and the compressor working for nothing...
what really affects your fuel consumption is your TIRE PRESSURE and UNNECESSARY WEIGHT you carry at your trunk or too much accessories, wheel alignment and brake problems.
May 6th, 2009 06:14 PM #27
