Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
    Quote Originally Posted by alexatl19 View Post
    Habang naka-on yung a/c bigla na lang pong may lumabas na usok galing sa vents. Ano po ba ibig sabihin nun?
    thats a sign of good ac... its able condense the moisture in the cabin.
    Sep 2018
    #22
    Thank you sir. Kinabahan ako e bigla kong pinatay aircon. [emoji23]
    naka max ata bro.. pwede mo naman iset sa medium. baka mag dry ang sinus. toyota ba or nissan?
    Sep 2018
    #24
    Honda city 2012 sir. Naka defog po kasi nun tapos maya maya bigla kong napansin may lumalabas na usok.
    Sep 2018
    #25
    Pag may fan po ba yung headlight papasukin sya ng tubig? May nabili kasi ako novsight led headlight tapos yun ang sabi ng nagkakabit baka daw pasukin ng tubig kasi may fan.
    Hinde paano papasukin wala naman tumatalsik na tubig sa likod ng headlight unless Iidaan mo sa ilog, pero pag ganyan mas malaki problema mo kesa pasukin ng tubig headlight.
    Sep 2018
    #27
    Thank you sir! Marunong pa kasi yung nagkakabit e. Haha
    Sep 2018
    #28
    Mga sir ano ba yung madalas tinatamaan sa ilalim ng kotse pag sumasayad ng humps? Pano ko malalaman kung may damage?
    normally sa harap yun front lip, transmission pan, engine oil pan, then yun lower assembly. meron naman cover yun just ahead of the lower assembly.
    Sep 2018
    #30
    Parang solid na solid yung tinamaan e. Lakas pa naman.
    Sep 2016
    #31
    Baka yung jack point/lift point yung sumayad?
    #32
    it can be anything.
    sometimes, it is not the lowest part of the undercar.
    sometimes, it depends on where the tumatama is located.
    oil pan (yikes!).. tambucho.. lower shock mounting.. floorpan.. bumper!
    look under the car, po. if the sound is as loud as you describe, there should be marks.
    have your car lifted at a gas station, to make the search easier.
    pag may punit, kitang kita yan.
    if metal, sometimes the part that got hit is shiney, or rusty, depending on water... pintahan nyo po, kahit red lead. para hindi kalawangin.
    sometimes, the paint wasn't abraded off, but there is a noticeable shiney depression...
    Sep 2018
    #33
    Mga sir ano magandang size upgrade para 175/65 R15 ng honda city? Kaya ba yung 195/60 sa stock rims?
any comment on this shop
