Results 21 to 30 of 52
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Sep 2007
- 20
October 12th, 2007 07:20 PM #22Speedyfix,
Okay It work for me.saka pinatanggal ko na ang thermostat for better circulation of water.Ang tagal bago ako nakakita ng marunong sa electrical talaga...Almost 2 weeks ata of course di lahat ng araw pwede ako..Thanks Sa lahat ng tsikoteers..
THANKS
nurse on wheels
- Dec 2006
- 392
October 12th, 2007 08:03 PM #23the thermostat is there for a reason. since you changed it to a new OEM one, there's no point in removing it. there's a separate thread which discusses this issue.
- Sep 2007
- 20
October 12th, 2007 08:30 PM #24Moe,I Agree!!! dapat di ko pinaalis.i read the Thread The Great Thermostat Debate yata...At read and read and read whew ang haba..pero sa mga with thermostat ako.So babalik ko na bukas..Thanks
- Nov 2003
- 3,849
October 14th, 2007 02:57 PM #25problem wasn't with the thermostat if gabi lang tumataas or pag may load. a busted thermostat will cause you to overheat at any time.
October 15th, 2007 03:37 PM #26
Mga pare,
Ask na lang din ako, what happens when the coolant reservoir overflows with boiling coolant? I experienced this last Saturday. I was driving for around three hours already, when I noticed a spike in the temperature gauge (hindi pa naman red line). When I stopped and checked coolant was overflowing with an accompanying hissing sound. Hoping for your replies. Thanks and God Bless.
- Nov 2003
- 3,849
October 18th, 2007 10:37 AM #27check the fan and thermostat... that means you're close to overheating na ng sagad.
October 20th, 2007 09:58 PM #28
Sir Lerual, try mo din mag palit ng brand ng coolant baka makatulong din sa prolema mo. Di kasi lahat ng coolant pare-pareho.
October 20th, 2007 09:58 PM #29
Sir Lerual, try mo din mag palit ng brand ng coolant baka makatulong din sa prolema mo. Di kasi lahat ng coolant pare-pareho. Good Luck.
- Nov 2003
- 3,849
October 21st, 2007 08:39 PM #30any brand should work pretty well naman. almost all coolants are made of the same basic makeup naman and will help increase boiling point and increase lubrication of waterpump etc.
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
