Results 11 to 16 of 16
April 12th, 2012 10:39 PM #11
I wonder if if in cases like this... a DIY radiator flush using Whiz would improve radiator performance dramaticaly ...or radiotor cleaning would be a must. i ask cuz i think ill be in the same boat soon....
April 13th, 2012 10:49 AM #12
Flush
pro: DIY
con: iikot lang sa makina mo ang dumi
Clean
pro: malinis
con: labor and risk of cracking plastic top
Replace
pro: bnew
con: mahal
May 1st, 2012 03:15 AM #14
ganito din po case ng sasakyan ko ngayon, tumataas ang temp kapag ON ang Aircon.. Rayban na '96 po ung kotse..
una akala ko AUX fan, or thermostat or freon, pero now pinaka napansin ko lang.. during sa operation nung car bigla nalang magiging stuck na naka ON yung compressor dun nagsisimula ng tumaas yung temp nya.. normally kasi nag ON and OFF sya kapag ginagamit yung car eh.. alin po kaya nag kukontrol nung ON/OFF ng compressor?
- Jul 2011
- 262
May 6th, 2012 08:34 AM #15share ko lang experience ko,minsan kase tumataas din yung temp ko kapag naka-on yung A/C lalo na kung naipit sa trapik at minsan naman eh kapag long stretch yung daan na paakyat kagaya ng Lian/Nasugbu to Tagaytay road, try ko mag-flush pero walang naging epekto kaya pinacheck ko na radiator ko (04 Kia Pregio-2 rows). ang sabi nung nagcheck wala naman daw leak or crack pero kailangan na daw linisin dahil hindi raw maayus magcirculate ng coolant. Yun nga at Nakita ko daming barado na tube at parang putik putik lumalabas habang nililinis. After linisin..ang sabi eh maayus na yung pagcirculate.
test drive at monitoring na lang but so far ngayun medyu ndi pa tumataas ang temp minsan na natrapik sa calamba/los banos..
- Nov 2007
- 164
May 11th, 2012 11:42 PM #16pag nagpa carwash kau..palinisan nyo na rin ang radiator at ang condenser...at check mo kung naghihigh ang aux fan nyo.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
