Results 161 to 170 of 174
- 52,731
May 25th, 2016 09:45 PM #161they're not exactly interchangeable.
someone fitted my sentra with the "cheaper" evaporator (laminated?) when my original sprung a leak. it was terrible! it didn't get cold enough, and it iced up.
i got fed up and replaced it with the more expensive evaporator (serpentine?), which is what my car had originally. it restored my aircon to as-new condition.
- May 2019
- 12
May 19th, 2019 05:18 PM #162Ano po kaya pinaka the best na compressor for lancer boxtype SL 4g33 ? Namamatayan kasi ako ng makina kapag paahon ang daan. Salamat
Sent from my Flare S5 using Tapatalk
- May 2019
- 12
May 19th, 2019 05:20 PM #163Ano po kaya pinaka the best compressor for lancer boxtype SL 4g33? Namamatayan kasi ako ng makina kapag paahon ang daan at naka on ang aircon. Salamat
- 52,731
May 19th, 2019 05:59 PM #164i used to box lancer. as i recall, my compressor was factory-spec, which wasn't small.
i have not experienced what you are describing now.
my guess is, there's probably something with the engine that needs kumpuni-ing. my initial wild guess, is engine timing.
that, or the driver needs to work on his footwork.
good luck, king.
check also your current compressor. maybe there is something wrong with it, causing it to have too much drag.Last edited by dr. d; May 19th, 2019 at 06:47 PM.
- May 2019
- 12
May 19th, 2019 09:43 PM #165Okay sir noted papa check ko nalang po yung mga suggestions nyo salamat.
- May 2019
- 12
May 19th, 2019 09:51 PM #166Okay sir noted papa check ko nalang po
Nararanasan ko lang po kasi mamatayan ng makina kapag paahon at naka on ang aircon pero kapag naka off naman ang aircon at paahon ang daan hindi po ako nag kaka problema o namamatayan ng makina.
Isang situation pa e yung namatayan ako ng makina along the way mga 30 mins na ako nag drive at naka on ang aircon traffic at tirik ang araw akala ko nawalan lang ako ng gas chineck ko naman ang fuel gauge kalahati pa so ginawa ko is pinatay ko na muna ang aircon and tuloy tuloy na naman na aking pag drive. Nag tataka lang kasi ako nung umuulan at naka on aircon ko di nanan ako namamatayan ng makina at wala naman problema. Sa tingin nyo sir dahil rin ba sa compressor to dahil hindi kaya ang load nito sa makina?
Salamat sir
- May 2011
- 481
May 19th, 2019 10:47 PM #167That's an evaporator temperature sensor.
It is a negative temperature variable resistor (NTC). If the temperature is high, the resistance is low, consequently, if the temperature is low, the resistance is high. So, if the wires leading to the sensor has high resistance, it would simulate low temperature. If the sensor connector was unplugged, the resistance would be infinite meaning it will cause the climate control computer to disable the compressor operation. Check the circuit resistance of the circuit first. Don't be an unthinking parts replacer.
The placement of the sensor is as follows:
With the inlet and outlet to the left, the sensor tip is at 43.5 mm from the mating edge between the upper and lower case and 159 mm measured from the edge of the evaporator on the right. That is the calculated superheated region (installation location of the evaporator temperature sensor)
- Jun 2005
- 3,774
May 19th, 2019 11:28 PM #168
- 52,731
May 19th, 2019 11:38 PM #169
- May 2019
- 12
May 21st, 2019 12:38 PM #170
Monk-owned R53
