Originally Posted by
happy_gilmore
an update on this.
blower motor ang talagang may sira.
last saturday, wala akong magawa, decided a DIY approach.
removed the fan (sa lancer, located yan sa likod ng glove compartment), nasa loob ng parang blower housing, fixed by screws.
after removing everything, tried running the fan outside the housing. ayun. ayaw tumakbo. parang stuck up yung motor. what i did is to temporary sprayed the moving parts with WD40, ang medyo tumakbo. yun nga lang maingay dahil parang may resistance. this is the same as yung ordinary electric fan na may resistance sa propeler kaya ayaw tumakbo kaagad once you switch it on. so definitely, baka carbon brushing problem.
tried sourcing out for parts dun sa may amin sa las pinas... one shop carried auto aircon parts (including compressors, evaporators, blowers, expansion valves, anything, as long as car aircon... in fact, nakakita pa nga ako ng mga vents for L300 eh....). pinakamalapit na blower is 2200.00 pesos. denso brand (which is also the same brand nung lancer). pag balik ko sa house, baliktad ang takbo ng fan, so that sobrang hina ng hangin. tried exchanging my stock fan dun sa bagong motor, pero mas malala... walang lumalabas na hangin....
just returned that part (buti na lang, ni-refund). sabi ko di pwede.... although, may mga na try pa akong ibang brand new blowers from the same store, pero hindi sya kasya sa blower housing so di makaikot maigi yung fan.
temporary solution: again cleaned the fan and the motor. kinabit ko ulit... although tumatakbo sya, medyo maingay and nakakaasiwa. will try to have the motor opened sa aking suking electrician next weekend. in the meantime, pagtitiisan ko muna yung ingay... malamig naman eh....
for information: eldorado and citimotors (nag canvass din ako dun nung saturday), carries the part. but for a very huge amount of 12800 pesos.
