Results 41 to 49 of 49
- Dec 2015
- 183
July 30th, 2018 01:29 PM #42
July 31st, 2018 09:46 AM #43
Kahit anung sasakyan, you can do this procedure.
1) Remove the cabin filter.
2) Switch on the aircon (blower only) and set to max/high setting.
3) Point the Lysol spray beneath the glove compartment. Spray intermittently. Adjust the aircon's route flow so that the Lysol will reach different chambers of your aircon.
Note: Open your windows while doing this.
Hope this helps.
- Dec 2015
- 183
July 31st, 2018 01:45 PM #44Tnx much. 2 yrs na mux ko wala pa din cabin filter
Sent from my ASUS_X018D using Tapatalk
July 31st, 2018 01:52 PM #45
- Dec 2015
- 183
- Jul 2013
- 2,450
July 31st, 2018 03:09 PM #47This is how I do it since 2012.
Additional suggestion.
**Do it at night when you are parking the car for the day. In this manner, Lysol will stay in the aircon vents long enough to kill the molds.
**Before parking, turn off AC but leave fan running for a couple of minutes to dry the inside of the aircon.
**If there is a chance, park you your vehicle under the sun (of course turn off engine then go to your office). This will heat and dry your aircon system. Molds like damp environment. Drying will kill them.
- Dec 2015
- 183
August 1st, 2018 01:45 PM #48Tnx again for the additional inputs sir
August 29th, 2018 02:31 PM #49
Try mo linisin cabin filter mo...nangyari n sa akin yan, pagtanggal ko ng cabin filter para may basa n mabaho...di ko alam kung saan nanggaling...nilinisin ko at nawala ang amoy
Sent from my SM-G610Y using Tapatalk
Suzuki JIMNY [merged threads]
