Results 11 to 14 of 14
June 9th, 2009 12:07 AM #11
hello mam saan sa taguig kayo nagpagawa? dito lang po ako sa tuktukan taguig lapit sa old goldilucks
san po kayo sa tipas?lapit lang pala natinLast edited by aga_cruz; June 9th, 2009 at 12:12 AM.
June 12th, 2009 05:57 PM #12
i agree with that approach, palitan mo muna yung thermostat caus eit seem's to me from your story and what they have done, it's cooling ng nag direct sila, so meaning the compressor is still working. change thermostat and observe again. it's your cheapest & easiest way out.
if you want to be sure, bring it to ceejay's since ito ang mas malapit sa iyo or an aircon shop na kilala mo. dami kasi lokohan pag dating sa aircon just to make a quick buck specially pag babae ang nagpapagawa. in short, get a 2nd opinion.
- Dec 2007
- 48
June 17th, 2009 07:21 PM #13pareho tayo ng sasakyan 97 model manual gear din yung lancer ko at nangyari na rin sa aircon ko yung hangin lang ang lumalabas lalo na kapag naka low gear or nakahinto sa traffic light ng matagal.pinatingnan ko sa mekaniko at ang resulta kulang lang pala ang freon gas kaya mula nung pinadagdagan ko ng gas (2 months ago) maayos na ang lamig.
June 18th, 2009 02:36 AM #14
yakanyaw,
before jumping into often wrong conclusion, have pressure tests done on your climate control system. the hi side usually reads at about 270 +/-10 psi and the low side will be around 27 +/- 2 psi. this will tell you the more or less complete story if your expansion valve is stuck open/closed and if the compressor has lost its ability. any trained technician knows this. these pressure specs are used for the R134a refrigerant. if your refrigerant is contaminated or is the wrong substitute, you can not use these pressure specs and the whole system be flushed to remove all traces of contamination. some of the refrigerants are not pure specially if it was recycled in a not so well maintained recovery/recycling/recharging machine. you have mentioned you had it topped off. there might be a considerable amount of impurities and moisture in the system. try to do the touch/feel checks and diagnoses in conjunction with the pressure tests.
jick
certified auto
guam
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
