Page 37 of 42 FirstFirst ... 27333435363738394041 ... LastLast
Results 361 to 370 of 413
    Jun 2013
    #361
    dinayo ko to kanina from manila ako, pinagawa ko un a/c ang van dahil hilaw ang lamig, nakita nila yung butas na hinde nakita nun dati kong pinapagawan 2x ako bumalik for backjob dahil nawawala lagi lamig, sa ceejay organize at kumpleto sa gamit balik lamig ng van ko, balik ako after 1 week for check up.. may libreng meriendang pansit at softdrinks salamat kay ms marissa...wasn't able to meet m'cora and sir joel
    at was able to get the 10% discount for being tsikoteer :D
    recommended a/c shop, kahit malayo sa akin sulit ang byahe
    Jun 2013
    #362
    Apr 2010
    #363
    Quote Originally Posted by xoom View Post
    dalawa lang ang aircon shops na pwede mairecommend if you want hassle free jobs: CEEJAY'S and others.
    I travelled all the way from Antipolo to have my starex's busted compressor replaced and over-all system cleaning na din. I brought a brand new OEM compressor, Halla.
    Hayup trumabaho ang ceejay's, that's all I can say. customer satisfaction talaga. hindi tinitipid ang quality of service. hands-on si joel kase sya ang final na titingin at magtetest ng trabaho.
    natapos ang starex ko na nasa 4degrees ang interior temp. umuwi akong nangingisay sa lamig. I thought siguro gabi lang kaya ganun kalamig pero the following day tanghaling tapat at tirik ang araw, ganun pa din kalamig. napapailing na lang ako sa galing ng ceejay's.
    2 thumbs up talaga ang ceejay's. nothing but good words din si maam cora kay CVT. Gwapo at mabait daw :-) Ayaw din daw tumanggap ng discount offer nila basta pagbutihin na lang daw nila ang trabaho nila.
    I wonder kung saan binili yung ganyang compressor at kung mura lang siya compared sa sanden na meron si Ceejay?
    Sep 2012
    #364
    Details ng pinagawa ko sa Ceejays last month
    1) Replaced Shaft Seal pati compressor nilinis na rin
    2) Evaporator Leak Test... kasama na rin palit ng expansion valve and drier
    3) Changed my old condenser with a bigger and laminated one
    Sep 2012
    #365
    Results
    1) Reading after installing everything
    2) High temp reading at noon
    3) Low temp reading at noon
    Apr 2011
    #366
    gud pm mga boss, maganda ang feedback ng CeeJays binasa ko mula umpisa ng thread. ask ko lang updates ng location ng shop, taga daang hari lang din ako.
    sa case kasi ng livina ko, may times (twice na) na mahina yung hangin lumalabas sa vents pero pag pinalakasan mo sa fan speed, maririnig mo na malakas na yung tunog ng hangin pero konti pa din lumalabas sa vents. pinatingnan ko sa nissan westgate, ang advice lang is kelangan tingnan/palitan yung filter and at the same time may tama na daw yung compressor. hindi pa naman pinapalitan yung compressor kasi magagamit pa din naman daw. subukan ko sa cj's since kakatapos lang ng warranty nung sasakyan. will try to post updates afterwards.
    #367
    Quote Originally Posted by jougz View Post
    ok ah... palit compressor kaagad?
    cabin filter lang ang kailangan palitan dyan bro.......
    you would only need to change the compressor kung wala ng lamig....
    Apr 2011
    #368
    Quote Originally Posted by 1D4LV View Post
    hindi ko pa naman pinapalitan boss pero inunahan na din ako na 30k ang damage pag papalitan
    nung unang nangyari yun a year ago ata, pinalitan lang naman yung filter. although andun yung pakiramdam mo na parang "misaligned" yung ducting sa vent, o kaya kung di na makalusot sa filter yung hangin kaya sa iba na lumalabas. nawala naman yun nung sunod na araw, bumalik sa dating flow yung hangin sa vents at dating lamig din pero balak ko din ipagawa/pacheck up pag may libreng oras na.
    #369
    sir jougz, you can take exit at Honda Alabang then turn left along Alabang-Zapote Rd and continue cruising up to Uniwide. konting tapak lang sa gas makikita niyo na yung Ceejay's sa left side. mas oks kung morning kayo punta para madiagnose ng mabuti.
    Sep 2012
    #370
    ^ be there by 7 am kung kaya mo kasi mabilis humaba pila dun pag inabot ka ng 8...
    Sent from my Windows Phone 8 using Tapatalk
AC repair shop in Las Pinas area
