Recently my a/c doesn't seem to be as cold as before. I dropped by the local a/c shop and they saw one of the big rubber a/c hoses (the one passing over the air intake) having oily residue on it. So they say there might be a leak.
I was in a hurry and needed to use the car so I just ask them to top it off. They did. However, only the rear a/c blew cold. The fronts were not blowing as cold.
The shop tells me it could be an expansion valve problem. They prescribed, replacing the leaky hose, a new drier, a/c cleaning, and 2 new x-valves. The total bill rounds up to around Php5k (includes labor and materials) but will take a whole day to do so I just set an appointment.
This evening, I was using the rig and the front a/c seems to blow cold again. It only loses efficiency in hot weather, maybe? Or did the R134 top off work?
Do you think the shop's diagnosis is correct? Anybody had a similar problem with their rigs before?
ang aircon ng mazda 323 glxi 97 model ko pina ayos ko may sira na hose saka pinalitan ang drier, expansion valve belt, at nilinis pro pag andar may lumalagatik sa compressor na kong naka idle lang.. sabi na sira daw ang compressor pero pina check ko sa iba sabi nila hindi daw na linis ng husto ang dinadaanan ng freon, nong una malamig pa ngayon la na manual lang po ang aircon. please help
