Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter Watch us on YouTube
Car Lights and Lamps Talk Thread, Philips X-Treme Vision Vs. Osram Night Breaker Plus in More Than Looks; New generation of the two most acclaimed and compaired Headlight bulbs.... Has anyone used any of the two? I called ...
Page 1 of 46 1234511 ... LastLast
Results 1 to 10 of 452
Like Tree9Likes
Thread: Philips X-Treme Vision Vs. Osram Night Breaker Plus
  1. #1
    Suki ng NLEX... locoroco777's Avatar
    Join Date
    Jun 2007
    Location
    Land of Heroes & Poets
    Default Philips X-Treme Vision Vs. Osram Night Breaker Plus
    I called one of the shops I know regarding the Philips Xtreme vision....and they said that the stocks will be coming in by the end of the month....
  2. #2
    Tsikot Member Rank 1
    Join Date
    Jul 2010
    Location
    MM
    Default Re: Philips X-Treme Vision Vs. Osram Night Breaker Plus
    saang shop po yan? how about yung NB plus?
  3. #3
    Tsikot Member Rank 3 wrcastro_ph's Avatar
    Join Date
    Up ko lang yung question.. saang shop makakabili ng Philips x-treme and how much po?
  4. #4
    Join Date
    Dec 2007
    Quote Originally Posted by wrcastro_ph View Post
    Sir regarding Philips Xreme-Vision, wala pa dito, pero makakabili kayo online sa powerbulbs.com. Kung Xtreme power, marami sa malls. meron rin ako na h4 for lesser price.
  5. #5
    Join Date
    Dec 2009
    alin ang mas malakas = osram all weather/philips xp 55/65 watts o ordinary na 90/100watts?
  6. #6
    Join Date
    Dec 2007
    @aeo62000,
    technically mas malakas ang 90/100w bulb. Pero subjective kasi ang pagiging "mas malakas" na headlight. Eto ang pros and cons sa mga choices mo:
    Osram All Seasons:
    Pros:
    A little Yellowish light, meaning more contrast pag bad weather.
    Malakas.
    Comes in 55/60w+30% more light, meron ring 80/100w.
    Cons:
    Hindi lahat gusto ng yellowish light.
    Higher wattage (80/100w) means upgraded wiring is recommended.
    Mid Priced (approx 400-500php per piece)
    Philips XP:
    Pros:
    stock wattage with +80% more light.
    no mods needed.
    well-focused.
    Cons:
    Shorter Lifespan compared to normal bulbs.
    Expensive (1.4k to 2.3k php per pair)r
    Lighting may not be bright compared to Hi-wattage bulbs (subjective).
    Normal 90/100w Bulbs:
    Pros:
    Generally Bright
    Cheap (other brands are sold around 200php per piece)
    Durable (if you stick with known brands)
    Cons:
    Needs upgraded wiring to be more effective.
    May damage plastic lenses.
    Not recommended by OEM.
    Please take note that lighting is very subjective. It's best to try out different bulbs on your own car and see what's best for you.
  7. #7
    Join Date
    Dec 2009
    thank you tech supporter, may available ba na philip/osram na 90/100 watts? upgraded na wirings ko. thanks again. planning to go with HID kaya lang ang upgraded ko na wiring babaguhin na naman, kasi di daw pwede, so might as well use higher wattage philip or osram, tama ba?
  8. #8
    Join Date
    Dec 2007
    Sir merong Philips na 90/100w, "Rally" model ang tawag nila, although madalang yun as mga auto supplies. Sa Osram, ang meron, 90/130w saka 80/100w. Use hi-wattage bulbs since upgraded na wiring mo. Try mo rin aang Narva, meron sila 90/100w
    Sir please delete your other duplicate posts sa ibang topics, bawal yata yan dito sa forum, thanks
  9. #9
    Tsikot Member Rank 4 harold13's Avatar
    Join Date
    Oct 2009
    kamusta NBreaker?
  10. #10
    Join Date
    Dec 2007
    Sir harold13, the NB's are considered one of the best bulbs, along with XP's, due to their power and focus while using stock wattage.
Receive Latest Car Lights and Lamps For Sale Alerts via Email
Enter your email address:
Delivered by FeedBurner
Tsikot Car Finder Latest Car Lights and Lamps Listings
Thousands of Tsikoteers see these ads everyday. Get better results with your car ads. Post your cars for sale at Tsikot Car Finder now!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Content Relevant URLs by vBSEO
Image resizer by SevenSkins
Copyright © 2011. Tsikot E-Media, Inc. All Rights Reserved
vBulletin Skin By: PurevB.com
